The w/shop manual says 20Nm for those caps... at that diameter like twisting them on by hand only...Don't crank em down real tight when you put em back on Phil.
Ditto!I'm preparing to change my fork oil in a few weeks, once the garage thaws out. This thread is scaring the %$%$ out of me.
That equals about 14-15 foot pounds (SAE). Barely more than snugged down.The w/shop manual says 20Nm for those caps... at that diameter like twisting them on by hand only...
168 inch pounds. Careful not to pinch/cut the caps' o-rings.That equals about 14-15 foot pounds (SAE). Barely more than snugged down.
Reminds me of a picture at work. It has a picture of the worlds most interesting man (XX beer). Across the top it says: I seldom cross thread a bolt. Across the bottom it says: But when I do, I grab an Impact and send it in.Torque wrench, who needs a stinking torque wrench. That's what impact tools were invented for.
Do you think someone had been in there before and overtightened. Every once in a while would come up against an oil filter installed by Magilla Gorilla, you know, tighten 3 additional turns after gasket makes contact.Reviewing this thread. We have encountered this problem on John's 07 ST-1300. We used heat, proper fitting 17 mm allen, breaker bar, air impact. Anchored inside the triple tree and in a vice with soft jaws. So far nothing has worked, but we are not giving up... gonna sleep on it tonight. Tomorrow, Nashcat, The Cheese, and myself will try to extract the offending cap.
The pie was procured locally...Details man , details!!! What kind? Procured locally or shipped in from some exotic location like Barstow? Inquiring minds need to know
Just to let you guys know, the fine group of folks attending the tech event was successful in getting the fork cap off last night when I was in the shower. They informed me they finally discovered the answer! PIE.... not the mathematical type, the fruit type. They did not tell me if it was the cherry, the apple or the pecan pie, just that they took a break and ate pie... went back to the shop and promptly removed the cap. So there you go, never under estimate the power of PIE!
