Frame bolt holes out of alignment
Chester, NJ 07930
2016 ST1300PA
I'm not the most mechanically inclined guy, and I managed to goof up what I think should have been a simple installation of some crash guards for the luggage on my ST. I removed two bolts as shown in the pic below. Now the corresponding holes behind this part are slightly out of alignment. I'm not sure what the right terms/names are for the parts involved. I think the solution may involve jacking up (very slightly) the part behind, but figure I'd reach out for assistance before making a small problem big.
TIA,
Chastened in Chester
Wasaga Beach, Ont. Canada
'04 ST1300 Blue STar
The aluminum part with the counterbores (for the cap screws),,, is called "side step". First time I removed both bolts,,, I lost the alignment,,, as you have. After that,,, I always only removed one bolt at a time. I was eventually able to get one bolt back in,,, being very cautious to not cross thread it. I will soon be doing the same task again,, as I remove BlueSTar's damaged tip over bars. Just work carefully,,, with levers or jacks,,, and you will figure it out,,, cheers,,, CAt'
You need to take the weight off the rear wheel as it is attached to shock etc.
Try board under wheel while on center stand, or carefully using bottle jack under shaft drive pumpkin.
jfheath
John Heath
Ilkley, W Yorkshire, UK
2013 ST1300 A9
000679
2570
Without those two bolts on both sides, there is nothing holding up the black tubed frame that loops around under the pillion seat. It doesn't drop so much as slowly lowers itself while you are not looking, being clamped by the bolts at the front.
The two bolt holes concerned are on this angled down tube just behind the battery on the right hand side, and just behind the fuses on the left (shown).
Sorry it is a blurred image - its a detail of the picture below.
Here is my bike a couple of years ago, getting a good clean up and the hydraulic pre-load adjuster being sorted out. The entire bike is balanced quite nicely on the blue platform scissor jack under the sump and the centre stand (which takes most of the weight). The bottle jack is supporting the collector of the exhaust, because the silencers are just held by the collector pipes and the edge of the ramp. The green circle is the bolt that supports the front end of the frame, and the piece of wood that was once part of the pallet on which the bike ramp was delivered, is exactly the right size to stop the rear end from dropping (ahem, 'add any further' to the end of that last sentence). It is relatively easy to lift the rear end up to make the holes align with the large alloy footres bracket. Put the front bolts in loosely to start off with, and have a narrow screwdriver handy to put through one of the holes as you lift the rear a tad. Then put the bolt into the other one. Again loosely. Then the other bolt.
The swing arm will not drop any further than it is.
In your case, remove the seat, saddlebag and top box if there is one. Find some way of lifting the rear frame up. (eg using the grab rails). The whole assembly is not particularly heavy and use a bar / screwdriver to slot through as soon as the holes line up. Slacken the front bolts to give a bit of freedom of movement.
The swing arm, suspension unit and wheel are all independant of this assembly so they don't add any weight to what you have to lift.
Montreal
2009 ST1300A9
Lift up or push down on the platform behind the passenger seat as required to line them up. The platform gives you leverage. It takes very little force. A second person doing so while you thread the screws is a lot easier.
STRider
Oregon
2012 ST1300A
50
Sorry you didn't get the same instructions as I did which clearly admonished, "Only remove one bolt at a time, install tip-over bar with one bolt, remove second bolt and rotate tip-over bar's mounting plate into alignment and then insert second bolt" or something like that. :)
I did this on one side when I installed the Goldwing crash guards. I happened to have a tapered bronze drift or punch that I used in one bolt hole to lever the subframe back in alignment to start one of the bolts. I would be hesitant to use a steel screwdriver for fear of buggering up the threads in the subframe. Harbor Freight has a set of bronze drifts or punches cheap enough for a one-use tool.
MURFREESBORO, TN
18 Gold Wing
7285
I made the same mistake. You could have a neighbor come over and left the rear up from the grab rails while you thread one of the bolts in. I used a ratcheting tie down hooked to the garage door rail and the grab bar and was able to ratchet the rear up enough to thread the bolt in.
Sadlsor
Birmingham, Alabama
2008 ST1300A
9065
Not that it helps the OP, but I got the same detailed instructions when I ordered the adapter plates (which many here do NOT use in mounting the GW crash bars) from @red dirt cowboy, which are sadly no longer available from him. @bygdawg stopped selling them before that.
Without the written admonition to NOT take both bolts out at once, I most certainly would have done exactly that, with the exact results of the OP.
Patchogue, NY
ST1300 - Black
Been there too.
I used one C-clamp and made a jack out if a bolt and nut. That fits on the inside of the cast aluminium frame on a ledge just below the black tube frame. To jack up the black tube frame and used the C- clamp move the holes sideways.
Retaped the Holes and replace bolts.
My problem side was where the fuses and relays are.
Note: You can use longer bolts too. just check they don't interfere with anything behind the black tube frame.
