OK, I still have that stupid wobble in the front end. It is present from around 40-60mph, and is terrible between 45-50. At those speeds if I let go of the handlebar it will shake violently to the point of bouncing back and forth from lock to lock. Above 60 it is smooth as silk, below 40 it is pretty much non-exsistant, maybe a lsight pulse at those slow speeds. I have had it up to 145indicated and it is still smooth, it never gets bad again, just at the previous mentioned speeds. I checked the tire pressure and the previous owner had been running them at 30psi front and rear. I set them up to 42psi and it didn't change anything, but the tires are pretty badly cupped. I still have a fair amount of tread left on the tires, and so I don't want to throw them away if something else is the culprit. Money is really tight right now thanks to my accident, but I should be back to work in about three weeks or so, which means I can't really spend much moeny trying to fix this thing.
At the advice of a friend who works on bikes I put it on the center stand, put some weight on the rear so the front tire is off the ground and checked for any amount of play in the steering head bearings. I turned it side to side, it felt very smooth and I could not get it to shake any at all. As best I can tell this should indicate the bearing is OK. I was wondering if anyone has any good suggestions of what to check next?
could shock oil level make it do this weird wobble at given speeds? Is there some way to check these pretty easily or do I need some specialty tools? I am a mechanic/machinest and I have plenty of tools and a pretty good knowledge of meachanic things, just no expereince on bikes. I may be overcomplicating things due to a fear of the unknown, but that's why I come here to feed off the knowledge of the great guys here.
Thanks for any suggestions. I forgot to mention it is a 2003 ST1300 NON-ABS
George
George
