Front modulator crank angle sensor.
mcpanman
Cooperman
Melbourne, Derby UK
ST1100 ABS/TCS
Hi All, New to this forum so I guess this may be a common question. Where the hell due I get hold of a front modulator crank angle sensor from. I am based in the UK and so far can only find the whole front modulators on ebay at high costs. Bike is ST1100AS 1995 model. Fault on ABS/TCS is code 1 front modulator and 20A fuse blows every time the bike starts.
Blrfl
Natural Rider Enhancement
Northern Virginia
Fast Blue One
4837
Honda doesn't offer anything smaller than the entire modulator as a part.
The 20A fuse is for the motor. If that's blowing, the modulator or its wiring has other problems, probably a short. The CAS fault is just a symptom because the ABS computer assumes the motor works and sees that the crank isn't moving.
--Mark
Bigmak96
R.I.P. - 2021/08/07
Rural Mn
04 GL1800 Past tense
7910
I picked a couple on eBay cheap. couldn't hurt to look there. They are all the same as I recall based on number of teeth.
Bigmak96
R.I.P. - 2021/08/07
Rural Mn
7910
Crap, sorry, I was thinking of the wrong part.
With a gifted, patient mech at hand are there *some* chances of reviving a modulator by taking it apart, soaking it in rust remover and giving it a few cycles in an ultrasonic cleaner...
Heliredcat
Very clean 95 st1100 abs/tcs
Palm springs ca
St1100
I had fuse problem, turned out to be stuck plunger in the modulator, baught a used modulator ,that was the fix
