I know its a bit of a late reply, but ........ If one side isn't wearing as much as the other side, it is possible that the caliper isn't moving on its slider pins. They might need cleaning and greasing. I dont know if you have an 1100 or a 1300, but this is much easier to do on an 1100. The 1300 has brake lines which prevent easy separation of the two halves.
The brakes are applied by pressure from the pistons which moves the outer pad onto the brake disc surface. The inner pads are moved in towards the surface as a result of the entire caliper body sliding across as a consequence of the pressure from the pistons.
So apply the brakes, the pistons move in, the caliper body moves out. Pads on both sides get the same pressure.
If something prevents the calipers from sliding out, the pressure on the outside will be greater, increasing brake wear. In addition, the pressure is pushing against the disk surface from one side only, which, over time, may cause problems.
Without the pads in, it should be possible to grab hold of the caliper and move it in towards the wheel and back out, relatively easily.
