Kevcules
I did read something common about these bikes having a slight pull to one side when letting go of the bars. I already tried the re-alignment process, maybe I'll attempt it again. It's not a terrible pull, but it does definitely pull. I've also tested the theory on having weight on one side in the hard bags with no real different results.Probably a better idea, but didn't someone else have this problem? Was there not a discussion about weighting one of the side cases? I cannot help but think the two problems are related - pulling to one side and fork problems.
What would cause a bike to pull to one side? The front and rear wheels being out of line - but our bikes have an axle that cannot be adjusted to twist the rear wheel (like a chain driven bike w/ rear wheel adjusters). Frame being bent - highly unlikely absent a crash. Could one dragging caliper cause this? I would think the hot rotor would be very obvious and pushing the bike w/ the engine off would be an instant giveaway that the brakes were a problem. Steering head bearings? Maybe. And out of balance bike? I've had over 10 lbs in a side case with nothing on the other side and not noticed a problem.
I haven't noticed unusual heat from the rotors and my bike always moves easy after riding. In fact, I'm so aware of the SMC issue, I always move the bike backwards a little after a hard stop to test the rolling resistance. So far it always rolls easily.....
