UK rider here.
I have noticed this years ago, and yes it was the other side. But It hasn't happened in the last 10 years / 100k miles.
The road camber is one issue. In the Uk, we spend longer leant over on a right hand bend than we do on a left hand bend. It is a greater distance. For USA the same is true for left hand bends. However this but has not been enough for it to show up in recent years. As soon as soon as the surface reaches one wear bar across the width, thats it, the tyre is changed. But there's never any sign of cupping as seen in your pics - not on my current model of tyre.
So what else may have changed to prevent this from happening now?
One is my mechanical experience with the ST1300. Another is tyres.
And I am certainly riding differently from the way that I rode 10k miles ago.
The answer may be a combination of all of them. If something is mechanically wrong, then certain types of tyre will show it up more than others.
Mechanical Issues:
Rough bearings are easy to detect in the garage, but worn bearings less so. One tell tale sign is a momentary 'falling off the edge feeling when you lean the bike that little bit further in a bend. I'm not talking about big lean angles here. It feels like riding on a squared off tyre.
Bearing installation. If your bearings have been changed, they may have been installed in the wrong order. One wheel has to have the left bearing installed first to meet the shoulder in the hub, the other has to have the right bearing installed first.
The second bearing doesn't seat against a shoulder. If they are installed in the wrong order, the front and rear wheels will not be in line with each other.
Front wheel and fork installation. It is important that the wheel is installed following the correct sequence. If not any misalignment can be locked in place when the axle is clamped.
Tyres
That cupping on the right hand side is typical of some tyres where a dual compound is used. Some wear evenly across the join, some don't. For me, the recommended dunlop tyres were terrible in this respect, and one of the Bridgestones (possibly BT021 - I cant remember) was bad. I have photos somewhere showing wear just like yours.
This picture below shows similar behaviour on the BT023 - the rear wheel - due partly to the harder top layer and the softer sidewalls, and partly due to inadequate damping for the load. But here you can see that the left hand side of the picture (right hand side of the bike) is more cupped than the left. The BT023 side treads wore down before the centre ran out of tread. In this case, we can eliminate fork alignment and bearings as the cause. Towards the end of their life, the sensation was one one of 'wallowing' in when leant over in a fast corner. Wallow ? Hippos wallow in mud and seals wallow or waddle their way across slippery surfaces. Yes - 'Wallow' is just about right.
When the harder top layers of the tyre wear to the softer compound, it wears very quickly. Although on your tyre, the uneven effect can be seen at the wear bars just either side of the centre line. The left side of the photo is still legal, the right of the photo shows the wear bar smooth with the main tyre surface. Well beyond legal. So whatever the issue is, it is not just to do with dual compound and leaning over.
I am finding the current Bridgestones T32 GT rated tyre to be pretty good for even-ness of wear. I never get any squaring off and the sides and top seem to wear at about the same rate for my load and style of riding.
Are they inflated properly ? 42psi is the quoted figure for st1300s front and rear.
Is your fork oil damping the suspension properly ? Suspension that pogos - boing-boing-boing - is going to wear the tyre badly, and combined with camber and longer distances on the outside of bends, this may result in what you are seeing.
Is the tyre installed on the wheel correctly. Check the direction arrows. (Although if this had been an issue I would have exoected big chunks out of the surface, not the all round wear that you have.). But check anyway.
Check the rear damping for the same reason. That is more likely to have an effect on the rear though.
How is your rear tyre ?
What make / model tyre do you have on ? They look like the tread on Pilot Road 4s. If so, are they a GT version ?
