Odie1
Installing a new front tire and felt my wheel bearings. Felt very slightly 'gritty', not perfectly smooth, so I decided now would be a good time to replace them. Okay, since I have 93K on the bike, it's probably way past time, but lets not go there.
I have not started yet, but have been reading several posts from the past on replacement, and can't seem to answer a couple of questions I have.
Seeing as how there is a spacer between the bearings, and it LOOKS from the manual it is sized just large enough for the axle to pass through, is there room enough to drive the left hand bearing out from the right hand side while the spacer and right hand bearing are still in there? Again - apologies for not investigating more before asking, but would like to know BEFORE I start blindly hammering on stuff! I've learned over the years to use the big hammer as a LAST resort, not on the first attempt.
Secondly, should I replace the dust seals while I am there... which leads me to my third question...
Lastly - was looking at Partszilla and they show 3 different part numbers for dust seals, and 2 different numbers for the same bearings? Is there any difference, or is that just different generations of part codes, manufacturing, whatever?
Thanks for any input before I start disassembly...of the bearings anyway ... tire and disks already off.
Odie1
Odie1
