Need some more help on this, guys. I have a related issue, I believe. Since removal of the petcock valve, the bike did not idle consistently. If stopped at a sign/light, the revs would continue to drop down and then stall.
Then I just let it sit for about 4 weeks after Thanksgiving to Christmas (it's been in the 30's here in PA). I tried to start it, and it wouldn't turn over even though the battery was on tender (had plenty of juice, lights were on). So, I tried to bump start it, and the tire wouldn't rotate even in 3rd or 4th gear. I did end up getting it to finally turn over, but it acted like it was flooded. And, then when it did run it seemed to be running on 3 cylinders. So, I checked the plugs, and one was fouled, and it appeared that there was a lot of fuel in that same cylinder (sprayed out when I checked spark...that was exciting
So, I replaced the plug, started it, and it ran, but did the same thing as before (didn't idle consistently and ran a little rough). I turned it off after running it a little while, parked it in the garage on the center stand, and tried to start it again this today. Again, it wouldn't turn over.
Is it possible, it is hydro-locking? If so, what could be causing this? Does this mean I have a stuck float(s)? Please let me know if you have any insights or things to check...
