Hello
I have a ST1100 with a build date of 11/99 and 93K miles. I was told it was a 2002, but based on the 11/99 build date, I think it is a 2000 model.
Currently, the bike will not take more than 1/2 throttle before it bogs and seems to "run out of fuel," completely loosing all power and refusing to rev until the throttle is reduced. It will then slowly rev but will start to break up as the revs climb. The bike then completely signs off between 4000-6500 rpm, refusing to rev any higher, regardless of throttle position or gear selection.
When I got the bike it would take only about 1/4 throttle.
Some further details for your consideration-
I have read here, and discussed with other mechanical friends the following possibilities-
I am pretty mechanically inclined- riding, wrenching and racing the last 25 years- HOWEVER - this is my first rodeo with an ST1100 and it's more complex vacuum and CA emissions systems. I am hoping you good folks might describe some trouble shooting processes, and/or post some links to fixes or tests.
David
OffShore1V
- I first found a nearly plugged fuel filter- Changed and had no improvement.
- Next, I found a torn Auto Valve Assembly diaphragm ( Automatic petcock) - I replaced the assembly & the bike now will allow 1/2 throttle before the sensation of "running out of gas" occurs.
- I tested the electric fuel pump by disconnecting fuel line from outlet of fuel filter and observing the following- When the key is turned on and the "run" switch placed in the "run" position the Fuel Pump can be heard to prime and flow is observed.
- When the start button is pressed, Fuel flow seems to be sufficient and consistent.
- The bike starts and idles in a seemingly normal manner. Choke is required when cold, but it warms to idle after a few minutes.
- The idle adjustment screw seems to function properly, allowing idle to be set where desired once engine is warm.
- Without load- (in neutral on the stand) the throttle can be opened further than 1/2 throttle without the problem occurring
- Torn Carb Diaphragms
- Air Cut Off Valve (not sure where these are, how they work, or how to test)
- Vacuum Problems
- bad or clogged "charcoal canister"
- My first hope is that you can suggest what the most likely culprit might be from your experiences and my symptoms.
- Second, my thought is that you may be able to help me with the easier steps to eliminate what it is not- so I can avoid going to the step of removing and disassembling the carbs without knowing for sure what the problem is.
David
OffShore1V
