On my 2001 ST1100 every time I go to fuel it up when low I turn the cap and woosh lots of pressure built up I think the vent house may be plugged. Has anyone ever experienced this and where does the line run to?
Thanks for the information I will ride it with the vent hose unhooked and see what happens next fill up.The line runs all the way down to the bottom of the motorcycle and exits under the engine. It is very possible, and not uncommon, for the line to become kinked. You can test it by squirting water into it using a plastic syringe purchased from a drug store.
But, having said that, it is more probable that the blockage is in the cap, not the hose. Just disconnect the hose from the cap and ride around for a few days, see what happens when you next remove the cap. There is a procedure published somewhere here in our community that explains how to clean out the cap if it is blocked, but offhand, I'm not sure where that writeup is.
Michael
