When I had the tupperware off my ST this past winter, I saw that there are a couple of small hoses leading from the upper tank to the lower tank(?). They appeared to be around 1/4" i.d. - this is an estimate since I did not pull them off the tank.
If I run the tanks down to around 1 gallon or so left, and fill up using your average gas station's 1" hose, will I fill the top tank, close the cover and drive off only to have the top tank drain down into the bottom tank leaving the top tank only half or 3/4 full?
I've not run the tanks much below 3 blocks on the gas gauge, but so far, this has not happened at fillups. Is there a bigger hose that I did not see that connects both tanks?
