Some time ago I checked the timing belt on the motorcycle I bought recently. With 160,000 km and no service history, I took the covers off to check the condition of the belt. Although it looks like new, I found that it was slightly weakened, I could rotate the cooling pump roller easily under the belt. I loosened the screw of the belt tensioning roller and let it stretch the belt. I tightened the screw back and reassembled the dismantled components. After doing this operation, I found that the engine did not heat up as quickly, the needle of the temperature indicator rising much more slowly. It is possible that, due to the widening of the belt, the pump was not activated enough. Then I decided to order another timing belt and I searched in different places, finding OEM or Gates T325 at different prices. In the country, locally, I found only one supplier whom I contacted and who informed me that this belt (Gates T325) is not in local stock and that it will be imported and wait for a week until I receive it.
Today I received the belt, packed in a plastic bag. It is marked "Gates T325", it is "Made in UK", it has a series of numbers and letters, but I cannot discover if it is original, how old and how safe. Is it worth taking the risk to install it? What do you advise me? I am also attaching a picture of what I received. Thank you.
