- Joined
- May 27, 2021
- Messages
- 1,027
- Age
- 63
- Location
- Coquitlam British Columbia Canada
- Bike
- 2009 ST1300
So... I love these brakes, I mean don't get me wrong, I still haven't figured them out, but having looked at that entire burnt mess yesterday I thought I'd go out and actually have a look at what I bought and have been blissfully riding for the last year.
Two things; first, I had to see if I had that right splash of coolant on the valve cover since I have added a few ounces of coolant, maybe I need a new brass tee, and second to check my brakes.
I've lost some coolant over my first twenty five hundred kilometers, when I first got the bike there was a very small puddle under it a couple times but nothing since, it seems that my 09 has a drain hose for the water pump weep hole vs earlier versions and I imagine that maybe it's the mech seal, will check after this weekend when I dissemble it, but meanwhile,
I noticed that my left front caliper has less pad thickness than my right; I'm guessing 3/16" plus compared to closer to 1/4" on the right, both discs seem very good with no glazing or grooves.
So... I revisited the brake system information here and relearned that when the pedal is pressed hydraulic pressure from the pedal master cylinder is applied to the rear caliper centre piston and the proportioning valve rear reservoir input port.
The rise in rear reservoir input port pressure channels fluid pressure sequentially to the left front caliper centre piston, and the right front caliper centre piston.
It seems [ or should I say, it sounds like ] that under moderate pedal braking, right front caliper centre piston actuation may not occur.
So... habitual moderate pedal braking might wear out front left caliper pads.
What I don't understand is....
Between left and right caliper actuation, through the operation of the PCV as a strict result of pedal operation, how much rear outer piston actuation occurs [comes into play and when] as a result of SMC actuation of the left caliper?
bit of a typo there, reservoir instead of PCV on some lines, and this is all with no actuation of the lever [front MC]
And then it seems there's a "break away" pressure, where PCV output pressure drops in relation to input pressure, where I guess, you can actually lock up the rear wheel, and still be able to roll the front tire [like you need to do sometimes] when the PCV input pressure decides...
What... It sucks to be you?
I know that by the time you get there, the ABS [if you've got it] will activate and you should never see it, and I know [as obviously Honda does] how useless rear braking other than balance through a ____ storm is when you're hauling down the center of gravity barely within a foot of the handle bars is while you're straight up, but especially while you're braking through the turns you need a better understanding since you can't separate them, wonder if you might be better off without that SCM activation in the twisties.
