Givi 52 top box
East Mids, UK
Dragging this back up from the dead, but .....
Is anyone aware of Givi parts distributors that would have the Satin Finish Trim Set? Here in the UK I got replacement rubber bungs/feet for the mounting plate and a new lock barrel and keys quite easily but I also need a trim set to get the box looking good again. I think i'd get away with either the satin or chrome finish; something is better than nothing!
Montreal
2009 ST1300A9
Found this on the U.S. Givi site-
Z684C SATIN TRIM SET E52
Not sure if it is the right set for your case? If it is if you do a search using the description Z684C SATIN TRIM SET E52 as your key words it is for sale all over.
jupiter, FL
2007 ST1300 ABS
Has anyone wired the brake light so far 52? My top box has lights already trying to figure out how can I wire bike to mounting plate section
Vancouver
2003 ST1300
I haven't done it on the ST1300, but I did it on a friends Suzuki Bergman.
Some things to consider are how often do you see yourself removing the rear luggage? Do you ride without the rear trunk?
If it was me and because of how much I remove the rear trunk I'd keep the electrical connection outside of the bike, but would choose a connector that can stand up the elements (and some di-electric grease for good measure.) If you don't plan to remove it very often, you could hide the connection under the seat and not worry about the connector as much but it will be a pain to remove the top case because you need to remove the seat each time. I would wire it so that the wire came out the back by the rear plate (I haven't tried this location before so you should double check clearance, the right and left hand sides do have ample clearance as I've tried this and routed wires through here before.)
Its best to source a connector where the connectors are hidden or protected so that if the bike is turned on without the top box connected that you won't accidentally short the connector. This is also important if you plan to ride without the top box connected.
If you plan to ride without the top box connected, I would ensure that you can get a plug that can isolate the electrical contacts from the elements or source a plug where having power applied to the connector will not cause any additional corrosion as that can cause you to replace the connectors yearly depending on the environment in which you ride and how often you ride. Being in Florida you will have saltier air and corrosion will be more of a concern than if you were more inland.
Before starting I would consider how much power the various lights will add to the load of the load of the system. These days this is likely not a concern because LEDs can consume so little power (especially compared to bulbs) for how much light they put out, but something to be aware of.
The easiest way to connect up electrically is a T-Tap, it basically lets you splice into an existing wire. Some of the T-Taps require you to still connect to it via a spade lug, if you've never done this before look at the type and how to use it before you purchase it / install it.
You can make your own wires by putting all the wires you need into an electric drill and slowly turning the drill on, as the drill rotates slowly feed it more wire. The rotation of the drill will automatically twirl the wires and allow you to have nice all together wire for all of the individual wires that you need. You can also source wires that are already insulated together and have a thinner but wider profile to make it easier to fit under the seat.
I know I didn't really give you a how-to on getting it done, and hopefully someone here has done it before so that they can give you specific wires etc to you, but hopefully this helps you figure it out.
docw1
Bill Rankin
Muscatine, IA
2012 ST1300A
4332
I've had my Givi 52 brake lights wired up. There's a connector underneath that makes contact with a connector on the plate. I've had trouble maintaining a constant connection, however. Haven't been able to figure it out just yet.
bill
Houston, Tx
2003 ST1300
5952
bill
Same here. Thought the lights were not working anymore but they checked fine when tested (using a small 9V battery on the contacts underneath the box). Seems to work again after polishing the contacts with fine sandpaper. Looks like slight corrosion had built up.
