Hondafarian
Received my Grasshoper driver seat today. Fitted the bracket to the rear of the driver seat then fitted the front seat to the bike, no worries.
Went to fit the rear seat and it would not go as it had around another inch or more to go forward.
What i found was it will only fit if you put the front seat in the LOWER position and i ride in the HIGHER position.
Also the rear seat would not fit in the MIDDLE position.
So with a bit of detective work
i found the problem.
With the new bracket fitted to the rear of the front seat, and the position set on HIGH, fit it on the bike as normal.
Now position the rear seat as far forward butting up to the rear of the front seat where the new bracket is.
You will find that the new backrest bracket at the rear of the front seat is hard up against the front plastic lip of the passenger seat unable to go any more forward.
What i did was with the rear seat still in the same position , mark on the front of the rear seat vinyl where the bracket is hitting .
Now take off the rear seat ,turn it upside down to where you marked the seat.
Take out about eight staples and as you do, mark the underlying plastic lip coressponding to the vinyl mark.
With a Dremmel tool i cut out a plastic piece 65mm x 12mm ( slightly bigger than the seat bracket ).
Now put the rear seat back on, you may have to work it a little but it should go on.
If it went on ok, take the rear seat off again and with a staple gun replace the staples.
You should be good to go.
On my bike i can get all three positions now, but only need it to be on the highest position.
I hope you understand all of the above, it worked for me.
Phantom
It just seems this backrest doesn't work well when the seat height adjuster is in the highest setting. Which setting are you guys using? Further, the backrest itself takes up almost 3 1/2" of valuable space over the rear of the driver's seat and that's where I need to sit to not have my knees uncomfortably jammed against the fairing. At 6'3" I'm tall but not NBA tall. It just seems this product isn't made for someone of my height. That's what I get for eating Wheaties as a kid.
