I have seen pretty much all the problems listed in this thread at one time or another. Never had a the valve situation tho. Worst I've seen was lipSTick when I first got her home. None of her valves was tight enuff to not be able to get a gauge in there. Yur very lucky to have not burned a valve.
I agree with previous note to recheck fairly soon.
One or another of my 1100s has had:
Bad fuel pump;
Bad fuel relay;
Leaking vacuum cut-off;
Dirty low-speed jets;
"Stuck" fuel enricheners.
The last is still an issue on lipSTick. #3 will not fire consistently until the engine begins to warm up. The linkage from the choke cable to #2 to # 4, across the bottom to #1 to #3 is too flexible. I've had'em apart, cleaned those enrichener valves, and attempted to "stiffen" the linkage. So far, nothing has worked. It's caused me hard starting at cold temps more than once. Ugh.
Glad you got your sorted out.
