2002 ST1100 - bought in March of 08.
Had heat problems when I bought it. over flow hose was pinched and had burst...flushed radiator replaced coolant and hose, then it would not heat up. Today replaced the thermostat. the old one, when I put in hot water opened and closed when cooled. I thought damn, it is not the thermostat. Then, holding the old thermostat up to the light and rotating it, I could see that in the closed mode (cold) only 180 degrees of the plunger that moves, was incontact with the body. IT DID FAIL OPEN, BY NOT CLOSING ALL THE WAY. With the replacement thermostat, the needle moved to 1/3 scale in about 4 minutes and stayed there even on the freeway at 70mph. The old thermostat would not move off dead cold until I was in slow (1st and 2nd gear) traffic then immediately went to 3/4 and the fan kicked on and would return to dead cold when I hit the freeway... The new one seems to hold temp and 1/3.
