One ov mine went out on last ride. Expensive to replace, the ones at auto stores do not fit! Any alternative?
Any H4/9003 bulb will fit the 1300 with this simple modification: bend back or remove the two lower locating tabs.One ov mine went out on last ride. Expensive to replace, the ones at auto stores do not fit! Any alternative?
Usually best to replace both at the same time, or you could have different shades (color) of headlights...For a 1300! the 1100 is from CB1100F if you remember those! THanks I bought one of those and it didn't fit because of the lower tabs. Now I am wiser!
Thanks!
Never touch the quartz envelope on a halogen bulb with bare hands. If you do, wipe finger oils off with alcohol on a clean rag (better uses have been found for the stuff). Finger oils on the 'glass' will cause the lamp to fail as quickly as 2/3 of its rated life.For a 1300! the 1100 is from CB1100F if you remember those! THanks I bought one of those and it didn't fit because of the lower tabs. Now I am wiser!
Thanks!
