Ok...I've asked before but I'm just not sure I'm outlining this.....
1. My engine heat has never been this bad, but now it all of a sudden spiked.
2. It all started with rough engine idle.....it would bog down and drop below the 1000 RPM level.
3. I adjusted the idle and then the heat spiked.
4. Even though the heat feels as if the plastic is going to melt, the temp bars never change from the middle.
So my questions are:
1. What could be causing this?
2. Could there be a significant problem and the temp gauge isnt showing it?
3. Can the temp gauge ever be wrong?
4. Assuming that this is NOT the usual too hot issue, but something seriously wrong, could it be the coolant pump has failed?
5. I'm lost and need help.....any thoughts?
