The best cure I have found is highway wings. JMHO
Funny thing, you can't feel it in the winter.Thats a great idea "GO FASTER" lol,i pick up my very expensive plastic deflectors tomorrow so that will be my first step.And i hope it starts cooling down soon that will help a little im sure because when it gets cold i will want the heat on my legs lol
Hope it helps.Ok so my deflectors came in today i cant wait to get off work and go install them,im glad there rubber instead of plastic i will let everybody know soon how good they work.72 hour dry time so let you know in a couple days
This is actually pretty easy to do... just 1 screw under the headlight and a few push pins... Some find it helps a lot, I've never tried it myself.i have heard i could take apart my inner fairing
.SPEED396 said:My next step is to look into shin gaurds,someone said they helped them so thats my next step...
I remove my cowls for summer, and reinstall for cooler weather. I use a zip-tie when the cowls are out to better hold the side panels in. I only learned about the zip-tie this year, the last 3 years I just removed the cowls without adding the zip-tie. I tested the bike to top speed with the cowls out, nothing happened, nothing broke.My bike was so hot it just couldn't be ridden, on even a moderatly warm day. I took the advice from alot of people on here and took out the inner cowls. I took it for a ride and it definately helped but I found the outer fairing pieces were coming apart under the headlight corners from the wind blast. I then sawed the cowls with a bandsaw to remove most of the material and just leaving the corners to hold the fairing together. It made a big difference, and now that the temps are colder I just reinstalled the remaining pieces(no tools required) and now enjoy some warmth. They will come out again next spring.
