rwthomas1
Hello All,
I didn't know where to put this post. Heated accessories seems to be about the wiring, etc. and not the actual clothing. So here it is. I purchased a nice set of Gerbing gloves from a Forum member and now I'm looking for a vest or jacket liner. I commute in an Aerostich, not sure if that makes any difference, but I'm going to ask the questions in a list:
1. Wiring: My plan is to run the wiring up to the steering head area and secure the coaxial plug there. Run the temperature control wiring back across the tank, velcro the controller to the gas tank door, and then run the wire into the suit through one of the side access pockets. Since I'm starting out with just gloves, I'm thinking secure the wiring to the suit lining with a few stitches? Does that sound reasonable?
2. Vest or jacket liner? Vest can be had cheaper, the jacket liner has advantage of integrated wiring in addition to the larger heating area. I'm not touring in winter, with day-long rides. I'm on the bike for 45min each way. I'm also not all that sensitive to the cold after a couple decades of working construction through New England winters. So I'm thinking vest....
3. I'm making the assumption that the less I wear the heated gloves, the longer they will last? The heating wires have a finite lifespan with regard to being flexed during use? So wear them when I need the heated feature, but use regular insulated gloves if they are enough to stay warm. Sound about right?
I guess the post is more of a "how the gear is used/best practices" than anything else, so any tips or hints on heated gear use would be greatly appreciated.
RT
RT
