ToddC
John, why is it not on the lift...?
Inquiring minds need to know.
T
T
Well a 700 pound plus bike is a little scary for me to be elevated on a block or center stand on the lift whilst pulling and pushing bits and parts around. And I kinda like sprawling on the floor on rugs. Shop is heated and relatively clean. Albeit I will put it up once the front wheel is back on for further inspection and other service.John, why is it not on the lift...?
T
Nice spot. I would change it around 20 k intervals at least. After inspecting the residue, seals and bushings - was apparent wear caused by degrading materials trapped in the fork. Although some is expected - dependent on your riding conditions, temp and rider input it - the damper and other parts might appreciate a fresh oil periodicallyHope it all goes well. Let's see.......former owner replaced seals (5weight oil) on my bike @ 31k miles. I bought bike @32k. Leaked at 58.6k miles, so I did full replacement of seals, dust covers, bushings, (SS8-10weight oil), washers, etc. Currently @86k all appears well. Wondering if I should just change fluid now. Just returned a few days ago from a ride to Bodega Bay-Ca.
Yes, those rubber well caps are soaked evertime I remove them.Also the SMC and brakes checked out - bled and made sure the SMC charged up Really worth the extra effort and for folks in the PNW we should do this annually. A lot of moisture in the rubber well caps.
It makes sense to replace all wear items since you had it all apart but the bushings in these pictures are perfectly serviceable.
That seal cleaner has been a God send. I had a couple of instances where my seals stopped leaking after cleaning. Little bits get between the seal and fork. I've fashioned a cleaning tool out of a clear salad container. Using a clean cloth found that the dust seals were cracked and replaced those first.Nice seeing your bike hovering on 2 stands.
My seals leaked at 43,000 miles also, May 2022 , got another 7,000 miles out of them by cleaning them with a thin plastic sheet wrapped around the chrome slider.
I'm hovering around 50,000 miles April 2023, just started leaking again.
My new OEM seals just arrived today in Blaine WA today.
Picked them up from partzilla, free shipping.
I agree age can be a factor, (same year bike) ride conditions for the life of the fork with hot/cold season, temps between 20-108 degrees, terrain and rider fubars don’t help Me I hit a road gator and bottomed out once and been on many a rough dusty road. Along with two up etc etc - I was lucky to get 40kLast year, I did a January ride from Cedar City to Elk Grove, Kaliforniastan, just over 1,300 miles. Most of the temperatures were below 40F and it was two lane desert roads, and I blew out my leftside fork seal. My 2012 only had about 33,000 miles on it. But I figured, it wasn't the miles as much as the age of the seals!
Believe it or not I was surprised at the ease of disassembly and assembly of the stack. After installing the seals I put the damper in and and just held the fork up a little off the bench and used a long allen to start the screw below and made sure stop cap was aligned. Hand tight and checked for proper set. I torque spec it after assembly@JohnK how about a picture of your 2x4 jig for holding the fork.
Hi Rob. After meeting you I wanted to ride your ST. Same as the one I had. I think miss that bike or something. It certainly seemed simple to me at the time.I just replaced my front fork seals with 10W as well. First time on this 2004 with 96,000 kms. Second time doing this and it was easier, ( other time was on my less fast red ST!!). I have the shop manual this time as well!! Now I just want it to STOP SNOWING in Newfoundland so I can begin my riding season.
Great to meet you as well. Come back anytime, and I will give you a proper tour of the East coast of our province! You blue one had the nice big middle tank pad!!!
