I must be blind...trying to find the post that goes into detail on modifying the Harbor Freight tire changer (had pics, etc.). Can someone please post the link to this thread? Thanks!
Ha.. your title threw me off.. that's the one I was looking for.. lolHere's a link to the mods I made on mine, based on the link Joe posted above.
https://www.st-owners.com/forums/showthread.php?t=29957
I suggest getting the lip blocks from the same guy that makes the Mojo Lever.
Okay, I've obviously done something wrong. I assembled my HF tire changer, and when I drop either of the 'center posts' through the arm and into where the wheel would reside, it falls down far enough that sits below the upper arm (there is about a 2 inch gap between the top of the pin and the arm. That wouldn't give it much leverage at all.
Is there supposed to be something in the 'main' portion of the tire changer that the center post sits on? It falls a good 3 inches or so into the center of the hollow main post.
I did have to unscrew and remover the 'cap' that would normally go in the hub of an auto tire. Did that so the motorcycle changing arm could slip down onto the main changer.
Advice??
: Another fwiw from a smug old coot . If you can't find a pallet, a 4 x 8 sheet of Home Depot's (or whoever) thickest plywood cut in half works nicely.That's the ticket. I was expecting the center post to rest on a 'base' someplace in the main stand. When I pulled it up a bit and tightened the top knob, it seems to be 'fixed'.
Now to find a wooden pallet to mount it on!! Mojoblocks and mojolever are under the christmas tree waiting for Christmas morning...a dabble of plasticote on the bead breaker and I should be ready to go! Bring on brother's tire for a trial run....grin.
So you actually have the tire changer bolted to TWO pieces of 4x4 plywood, right? I was waffling back and forth between going the 'pallet route', or going the plywood route, but had not considered stacking the sheets of plywood for thickness/stability.: Another fwiw from a smug old coot . If you can't find a pallet, a 4 x 8 sheet of Home Depot's (or whoever) thickest plywood cut in half works nicely.
I had them cut the sheet in half, (and if you're driving a generation 2 Honda CR-V, you'll give whoever's in the parking lot quite a show as you solve the puzzle of how to load the plywood.) then I put the two halves together and carriage bolted my changer through the sheets to sandwich them together.
I sunk four expansion anchors in my garage floor and cut all-thread rod about 3" long to mount mine. Takes about five minutes to set up an take down every time I change tires.So you actually have the tire changer bolted to TWO pieces of 4x4 plywood, right? I was waffling back and forth between going the 'pallet route', or going the plywood route, but had not considered stacking the sheets of plywood for thickness/stability.
Sounds SmartI got a HF motorcycle changer for xmas. I don't have the tire changer base (on purpose) and I plan to directly mount the motorcycle changer part to my hitch on the blazer. I already have the 2" square tube welded into a 90 degree and the hole drilled for the receiver pin, I just need to weld (or otherwise attach) the motorcycle changer to the 2" square and then I'll be all set!
And I need to make the teflon tabs to hold the rims.
What are you going to do for a bead breaker.. isn't that part of the HF base?I got a HF motorcycle changer for xmas. I don't have the tire changer base (on purpose) and I plan to directly mount the motorcycle changer part to my hitch on the blazer. I already have the 2" square tube welded into a 90 degree and the hole drilled for the receiver pin, I just need to weld (or otherwise attach) the motorcycle changer to the 2" square and then I'll be all set!
