honda radio / bluetooth
Ireland
2002 stx1300
l have a genuine honda stereo on my st1300 and was wondering if there is anything you can get so you can listen to the radio through a bluetooth headphone communication system (sena).l know you can get a bluetooth module so you can play your music through your stereo
but l can't find anything to do it the other way around.
Thanks
Reisterstown, MD
Not an AM/FM radio, but I stream radio stations across the net, through my cellphone and out my Sena helmet set.
Your factory Honda radio probably has a connector to mate with a factory intercom system. If so you should be able to adapt an output to work with Bluetooth dongles (highly technical term!) such as those above. Adapting a Honda com connector to a 3.5mm audio jack would be the only involved part.
You'd also want to be able to mute the speakers when using the BT dongle so that would take a little more work but should be difficult. Does the factory radio have a switch for speaker/intercom or is it automatic?
