Gene
That's MR CUPCAKE to you!
Anyone using this replacement spring on there oem shock? I'm really wanting a new spring/shock but at around $1000 versus $125 for the Hyperpro it might be worth a try and it does have a return policy if I don't like it. My question to anyone who has one is how is it compared to the stock spring when loaded 2-up does there seem to be any additional capacity with this spring? With the Sonic spring up front at 1.5 of sag the rear is just preload capable for me when riding single at 2 clicks from max. I'm really looking to add ride height when 2-up to keep the front/rear sag the same in both situations by cranking in more preload.
I guess the bottom line is if the hyperpro will minimally fix the issue for less than $150 delivered that extra money will cover at least 3 or 4 STOC events this spring
I've talked to the Hyperpro rep and I'm waiting to hear from him on what weight load the tech department says is max for there spring and how the rates compare to the stock 900# spring since theres is a rising rate spring
Thanks Gene
Thanks Gene
