Jeff, Just another little tip, if you need the advice on doing a good wire splice and solder. Use a Western Union splice, as shown in this video. Heat the exposed wire splice at one end and apply the solder at the other end to draw the solder through the joint.
Thanks for the video on soldering, I had forgotten how to solder properly. BUT Great news, I decided to change the oil first and still have not located the soldering iron but this gave me time to not just jump right into soldering and think....
What I did was start the bike up after the oil change and check things again and it was reading 15.8 volts. So I decided to unplug the 3p yellow alt wires while the bike was running and then the meter reading showed only 12.7 volts so I shut the bike off and plugged the 3p yellow alt plug back together started it up and it wasn't charging at all. So I thought there must be a bad connection like you and everyone said! so I shut the bike off and unplugged and plugged the 3p connector a dozen times or so and started the bike up and like magic the meter reading was 13.7v I feel sure that soldering the wires will fix this problem much better so later this afternoon or evening I will get the soldering done. Meanwhile the battery is back on the trickle charger so the alternator will not need to work hard and hopefully that will keep the VRR from getting hot because thats my last concern, it did get hot even when showing 13.7 volts. Someone, I forget who, said its normal for the VRR to get hot especially the heat fins.
Looks like we got it fixed! However, I didn't mention what happened a week ago, was at my mothers house and parked the bike in the shade of a tree and good ole mom backed into it and broke some stuff so now I am on the hunt for used parts. I need the right mirror case and blinker housing I think the mirror itself is ok, I might need a front brake reservoir, because the fall made some leak out but it hasn't leaked since then so not sure on that, and then I need a right side saddle bag. I will probably get this stuff off ebay unless someone has these items for sale in the color black.
I will report back in after soldering is done and hopefully let everyone interested to know that the problem is solved!
