Sadlsor
- Joined
- Jan 15, 2020
- Messages
- 4,290
- Age
- 66
- Location
- Birmingham, Alabama
- Bike
- 2008 ST1300A
- STOC #
- 9065
My turn signals and 4-way flashers are no longer working; I must have did somebody wrong!
Background: added trailer isolation harness for trailer wiring, powered by the rear taillight (not brake light.) This was done with the help of an electrician and rider buddy who has done lots of work on bikes. I got my trailer way far away, and ALL lights, signals, and flashers worked with the trailer attached, and rode home with no issues.
Weeks later, I added the quartet harness to power my Zumo XT, using a switched circuit. The GPS isn't powering on with bike power.
Also added Warm N Safe wiring - direct to battery - and that works fine, for gloves and jacket.
All other electrics working otherwise.
Today I finally had some time to explore, checked the main fuse on the right-hand side and it's good. Fusible link is intact.
There's a black box near the relays on the left side, and I think one of the mini fuses in the service manual said Turn Signal or Turn Signal Relay, I don't recall now, but it's a 10-amp and it was solid.
Found the turn signal relay on the left side, and called Larry because I thought I had to remove the rubber cover to test it. He said NO! so I didn't destroy it. I plugged the female side- the wired, non-relay white connector - into a couple of the other relays nearby and started the bike, but still no signals or flashers. I tried the turn signal relay on a couple of other connectors but not sure which ones; two were outboard - away from the center of the bike - of the turn signal relay. Still no flashers, but the bike started and ran, with headlights, hi-beam, horn and brake lights all working.
When I try to use the turn signals there is no audible clicking noise, and the front amber bulb on that side goes dark. Both sides do that.
I'm floundering, and am just guessing, doing plug-and-play, er, -pray.
2008 ST1300-A (ABS) with 28K and change, tires inflated to recommended pressure but I'm late with an oil change, and the bike is dirty but the tank is full of petrol.
I rode the bike today for a restaurant job nearby, and to get a car battery at Costco.
My left arm was busy in lieu of electric blinking bulbs to signal my intention at intersections. Do you think car drivers recognize the manual right hand turn signal?
Anyone who can help give me a sense of direction to track this down and repair it, would be appreciated. Surely it's something stupid-simple?
