- Joined
- Dec 21, 2004
- Messages
- 4,348
- Age
- 70
- Location
- Ledgewood, NJ 07852
- Bike
- 03&04 ST1300
- STOC #
- 5079
I hope that was it Jeff good luck.
hey Jeff, sorry to hear this is still unresolved. I lost track over the dozens of posts, have you scrutinized the fuse block for a flaky connection or even an intermittent fuse? perhaps the 4250 RPM creates a buzzing that opens some small mechanical failure in the electrics.
I did pull and examine the fuses that seemed relevant. Trying to remember, I think they were labeled EFI and Ignition? They looked fine and the connections were clean. I put them back in the other way 'round, just to force a new contact
My bike has developed a similar hic-up. Last year once or twice the bike just shut-off and restarted while cruising the highway. Maybe happened two or three times the whole summer.
Now.. it happened a couple of times this month, three times this morning on the way to work. I would say mine is just over the 4250 rpm, but just as I was thinking that it happened when I was clearly over the 4500 rpm line. So it was probably at that particular rpm just because I spend most of my time cruising there in the morning with little traffic.
Maybe it's similar to yours, maybe not... but I don't seem to have any other symptoms of bucking or mis-firing. Just bike engine is off, then on and my cheeks are a little tighter.
Seriously though why it only happens when the bike is warmed up at a specific and reproducible rpm leave me with no guesses. Blrfls though of a scope and looking at what really changes when it happens makes me wish you had one to sniff around.
This does sound similar. It's like someone is flicking the kill switch on and off quickly. My bike does not completely quit running though.
This does sound similar. It's like someone is flicking the kill switch on and off quickly. My bike does not completely quit running though. Is that what's happening to you when you say it shut off? You have to hit the starter to get going again? Does your tach needle bounce when this happens?
This is why I keep thinking power, and it's reinforced by the the fact that the FI light isn't illuminating. If it were a sensor problem and the ECM was still running, there'd be a complaint about it.
Some of the reading I've done about car ECMs says that watchdog resets, when the software hangs up and the whole ECM has to be reset, are pretty common enough and recovery happens quickly enough (< 10 milliseconds) that drivers don't even notice it happening. If that kind of design carries over to motorcycles, it fits your situation pretty well: power goes, fueling and ignition stops, the engine runs a few revolutions on inertia, power returns, the ECM sees indication that the engine is being turned over and starts fueling it. The difference between a watchdog reset and a power drop is that you lose the engine long enough to be visible.
Yep, just like someone flipped my engine stop switch off and right back on. Don't have to hit the starter as the bike is just pop-started into running again. Never happened when sitting still or going slow, just when I am cruising on the highway. Don't know about the tach, would assume it stays measuring engine RPM, it happens so quick by the time I move the eyeballs the engine is running again at full speed. Not losing full electric power, my dash (fuel gauge, clock, etc..) does not reset and my phone does not beep like it lost and regained power. But the FI light comes on like the bike was just started, after five seconds it goes out. No error codes.
Tip over sensor?
For what it's worth, you can pick up a headless 'scope that plugs into the USB port on a laptop for under $150. It doesn't have to be a laboratory-precise, high-bandwidth unit, just something that can capture and store a couple of seconds on either side of the event.
--Mark
This sounds like an interesting theory because it would also explain the lack of error codes (can't throw a code while the software is being reset) but I think Jeff swapped ECM units with Hal's bike and the problem stayed with Jeff's bike.
Tip over sensor?
Thought about that, but once triggered the TOS requires a key off cycle to reset. Had one go bad on my ST1100 and I learned to cycle the ignition key whilst underway. Made for some pretty healthy backfires too!
I think what Mark is saying is that something external is interrupting power to the ECM or causing it to hang and re-set??? If that's the case it wouldn't matter which ECM was installed. The head spins trying to think what would cause that!
