Hi folks,
has anybody of you wondered why a dry ST 1100 (new engine) needs 4.3 litres of oil and any subsequent oil change including new oil filter is just 3.7 litres?
Here's the reason: the clutch is working in a separate oil compartment, the oil from the top of the engine flows into this compartment and part of the oil pump is acting as a scavenger pump to circulate the oil and mix it with the rest of the oil under normal operation.
This compartment holds 0.6 litres and is not drainable!
So whenever you change your oil on the ST 1100, the new oil is mixed with the old remaining 0.6 litres of old and contaminated oil. When pulling the oil pan you end up with a little mess.
In order to achieve a "complete" oil change I have come up with a solution that is described in pictures 1 thru 3: I drilled two holes into the oil pan, one from the bottom of the clutch oil compartment and one under an angle from the thread of the drain bore so that the holes meet in the oil pan wall. The drain bore hole is sealed by a silicone gasket in the drain plug. Whenever the drain plug is removed for an oil change, the clutch oil compartment is drained as well.
Works fine!
BTW, look at what I found at the oil strainer, not just on one engine, but on two different engines built in 1991 and 1998! Did not harm the engines thou, thanks to the sieve.
Best regards Eberhard
Works fine!
