In order to install a extend a fender (front), do I have to remove the fender or just by removing the tire I can do it?
Having done it twice, I recommend removing the fender. Epoxy it and rivet it. The first one came loose from the glue only, the second hasn't moved. Good old Honda, fender is a small item which has three different screws holding it on.In order to install a extend a fender (front), do I have to remove the fender or just by removing the tire I can do it?
IF you are going to attach the extension using ABS cement (I believe this is the preferred method - it is the method I used), you should remove the fender, because that allows you to place the fender itself upside-down and attach the extension from above. By doing it that way, you will ensure that no ABS cement will run down the outside of the extension... any drips will run down the inside surface of the fender itself.In order to install a extend a fender (front), do I have to remove the fender or just by removing the tire I can do it?
