Funny, we've been fielding similar questions in my household for the plethora of USB powered or charged devices we own.
A few tidbits of info. The Quick Charge standard is a Qualcomm product and explicitly works with the Snapdragon processor that's been exclusive to Samsung smartphones. Your benefit from chargers marked QC 1.0/2.0/3.0 may vary based on your device.
Next, the PD standard, or Power Delivery, is a newer standard, AND for high speed charging is exclusive to devices that use the new USB Type-C connector. As more devices adopt USB Type-C the advantages of PD increase.
"Overall, PD chargers are generally more powerful and versatile than QC chargers, but they may also be more expensive. QC chargers are designed for devices that use Qualcomm Snapdragon processors, while PD chargers are more flexible and can be used to charge a wider range of devices, including laptops and tablets."
QC (Quick Charge) and PD (Power Delivery) chargers are two types of fast charging technologies that are commonly used to charge modern smartphones, tablets, and other electronic devices. Here are the main differences between QC and PD chargers: Technology: QC and PD chargers use different technologi
www.linkedin.com
I installed a lighter plug socket on the left fairing pocket of my ST1100 into which I plugged my devices... those started with a lighter plug power supply for my CB radio, then a Garmin Street Pilot III and progressed to other lighter plug powered devices. By the time I bought my ST1300 in 2020, times had changed. Nearly everything I might power from the cockpit of the bike now gets its juice via USB - my smartphone, my GoPro, battery packs for powering those things off the bike, etc... I installed a three port, QC 3.0 bulkhead power supply in the right fairing pocket; something very similar to what Alberto posted.
When I was still using my RAM Quick-Grip cell phone holder I also used an SAE-to-USB device like Will posted. It worked great, until vibration killed the camera in my Samsung S21 Ultra phone, so I switched to the Quad-lock with the vibration damper and its wireless charger. Both work great at charging/powering devices.
If I were to make a couple suggestions...
Choose devices which explicitly specify GaN (gallium nitride) technology. GaN is a much more compact and efficient technology than the pure silicon devices it displaces. They draw less power than what they deliver compared to silicon. They can deliver higher wattage output to the devices which means they can - charge larger devices like a laptop, game console or tablet AND/OR charge them faster. They're also much smaller and produce less heat. IT IS THE FUTURE.
You've undoubtedly seen many USB chargers now labeled as including GaN or gallium nitride technology. But what is it, and do you need it?
www.zdnet.com
Switch to devices that use USB Type-C interface where possible. Type-C will be the de facto, no make that,
it is the official standard now, and will be for many years to come. The current specifications for both power delivery and data transfer gives the Ultra High Speed / USB Type-C standard legs for years to come. If the EU can bully Apple into replacing the Lightning cable with it, then you know it's got something.
USB Type-A interfaces will be around for a while, but its light is fading fast. It will be essential to support devices needing USB mini-B (Garmin zumo XT), older phones and devices based on USB micro-B (my Sena 10S communicator) and many of my battery banks and miscellaneous devices from the past ten or more years. So I would definitely recommend selecting a device which has both Type-A and C connections.
