So I have to ask... do you think the little fins on the ST1300's saddlebags are cosmetic or any chance they are there to break up the air flow? They are also on the Hondaline Top Box that also is designed to move left and right to compensate for rough air.Helical strakes are a common method on smoke stacks too. Look at most modern factories with a stack, and you'll see them. The strakes or equivalent would have to be on the bike, as far forward as possible ...not too attractive... so such does have to be designed into the bike IMO.
I'm pretty sure that those little ridges are there for cosmetics. Although if they were longer and taller (protruded more), they could have slight influence.So I have to ask... do you think the little fins on the ST1300's saddlebags are cosmetic or any chance they are there to break up the air flow? They are also on the Hondaline Top Box that also is designed to move left and right to compensate for rough air.
Yeah, all the tire pressures are what they should be so that's not the issue as far as I can tell. Not sure a steering dampener will help as it feels like the problem starts at the rear. Pretty much ready to sell it.Joe
What tire pressure are you running in the trailer. I was advised to not run over 25 psi and 22-24 is probably about right. This is for suspension and to prevent bouncing. It could improve your situation as well. A steering damper would probably help a lot. Not sure if anyone has ever added one to an ST1300. It may be a interesting project to add one. Also a stiff sidewall rear tire would help. As the oscillation of the trailer starts it can wag the rear of the bike back and forth on the flexible sidewall. Maybe a bias tire would be best. Just thinking out loud. My new(to me) Unigo is very stable at any speed on my St1100. I have run it slightly over 100 mph several times without issue. Where I live on near my home there is an area that there are pretty severe cross winds and wind gusts. I rode through this area several times to see if the cross winds would effect the trailer and so far it is tracking very well. This has to have something to do with the geometry and or aerodynamics of the ST1300 with the Unigo. My bet is on geometry. The ST1300 is known to be less stable than the St1100.
Dan
Joe, have you talked to Mark at Uni-go? I was there a week ago Saturday and was telling them about yours and BES's problems and at that time they had not heard of these problems. You might want to talk to them (if you haven't) and maybe they can help....beats selling it...if it can be fixed.Yeah, all the tire pressures are what they should be so that's not the issue as far as I can tell. Not sure a steering dampener will help as it feels like the problem starts at the rear. Pretty much ready to sell it.
That makes no sense.... If I never went over 70 I wouldn't have the issue...Joe, have you talked to Mark at Uni-go? I was there a week ago Saturday and was telling them about yours and BES's problems and at that time they had not heard of these problems. You might want to talk to them (if you haven't) and maybe they can help....beats selling it...if it can be fixed.
While I was there, two BMW riders came in towing their Uni-go's and I asked them if they had experienced any of these described problems...neither one has experienced excessive wiggle (mellow weave ) while pulling the trailer...but both of them did say they don't go over 70 mph while pulling it either.
If you decide to sell it...the bidding war on this site could be a lot of fun!
Sorry to hear that!Pretty much ready to sell it.
I'll add that to the list of thing to try thanks.Strictly for research purposes, have you tried pulling the trailer with the side bags removed from the bike? I'm not suggesting that is an adequate solution to the problem, but it may help you to isolate the problem. If it pulls straight behind the different profile of a bagless ST, then you'll know its a uni-go problem that is specific to the ST rather than a problem with the trailer itself.
I've got a uni-go myself that I have not pulled yet, so I'm very interested in your situation.
