skipcurt
Skip
Previously I posted that I thought I had a bad front wheel bearing. It turns out that I don't but I do have a front left fork leaking oil. I've read several posts about some fixes and have tried the 35mm film with what seems like little help. I have also ordered Sealmate which I haven't received yet. If you watch the video, they say you should slide the rubber seal out of the way to get down in between the fork and fork tube. Two questions:
1- How in the world do you slide the rubber dust seal up and out of the way?
2- How do you slide the black plastic fork pipe protector up and out of the way?
I can wiggle the protector about 1/8-1/4" back and forth but it will not slide up at all.
Just in case, here's the fiche from Ron Ayers. Numbers 18 & 26
Skip
Skip
