The factory installed bolts have a threadlocker installed but the manual says nothing about its use when reinstalling. I've also read about using anti-seize. What's the best practice? I'm inclined to use some red Loctite.
The service manual does indicate to replace the bolts each time they are removed. I don't do that but I do replace them after a few times. LocTite blue unless a new bolt is fitted.The manual says fit new bolts !! I ignored that for 6 years, always clean the threads, apply blue loctite, and re-use them, as I suspect do most people. (except last week when I bought it some new bolts for its 6th birthday). Honda reckon it is an ALOC bolt, but no one seems to know what ALOC actually means. 'Apply Loctite Or Crash' seems to be the most common suggestion.
Just curious, what is the torque spec and size of that bolt?.02 Honda specifies replacement for a couple of reasons including the legal dept.
They are torqued higher than a normal bolt of that size partly to the preapplied thread loc compound and partly because a higher torque provides a higher clamping force and stronger joint, a good thing if it's holding your brakes on and good for bolt reliability.
