Does anyone know where to buy socket head air box screws? Motorcycle gear does not carry them anymore?
Why not just order the factory screws, and then use the correct tool for the job. (JIS screwdrivers)Norm reccomends dipping the tip of the screwdriver into valve lapping compound to help grip the head on questionable screws.
Thanks. Did not know they were JIS. Do you happen to know the size for the JIS screw driver?Why not just order the factory screws, and then use the correct tool for the job. (JIS screwdrivers)
Available at McMaster Carr.
I've removed several air box base screws with these JIS screwdrivers, and have never damaged a single screw in doing so.
Ya gotta have the right tool for the job.
McMaster Carr sells a set of three JIS screwdrivers at a very reasonable price. Very good quality tools made in Japan - You would not believe how much better real JIS screwdrivers fit the Honda fasteners compared to regular screwdrivers, makes it almost impossible to strip out a screw head.
Dan
The JIS screws and screwdrivers also have a sharper edge where each leg of the cross of the phillips meet in the center. This prevents the screwdriver tip from walking out of the screw head when twisting the screwdriver.Touch the very tip of a standard #2 Phillips to a grinding wheel to knock the point off, it'll fit a JIS screw a lot better. And I mean just the very tip. Easy to remove more but real hard to add any back.
I removed some really stuck screws on a set of carbs the other day without ruining any.
