Pred8tor said:
I need help in locating the adjusting screw up under the fairing behind the headlight. Even when I crank the dash adjustment knob as high as it will go, the low beams are still too low, and I wind up flipping over to the high beams and turning them down to act like low beams.
I've read about the existence of the screw, but when looking I can't seem to find it. Any help would be greatly appreciated!
It's waaaay up under the fairing.. If you put the bike on the center stand,
and look up into the fairing along the inside the left hand fork, you will
see white plastic knob with a phillips slot on the inside. I can't remember
the size of the socket (17mm maybe) will fit over the outside of the knob.. To adjust, run your headlight to the up position and then
turn the adjustment knob... I "think" looking from the bottom, that
clockwise will elevate the headlight... But heck, it might be counter-
clockwise (anti for across the pond ).. Someone will post the
correct direction... I adjusted mine when I first got my ST...
Dont set it too high, if you ride double, you might not have
enough adjustment (dash knob) to get it low enough and
not dazzle oncoming drivers..
Putt...
