Melting Temperature Gauge
Deux-Montagnes, Quebec, Canada
2000 ST1100Y
9063
On my newly acquired ST1100, I notice that the plastic had started to melt, right under the temperature gauge.
At first, I thought that a previous owner had probably burnt it with a cigarette. But then, I saw some dashboard on ebay, burnt at the same place.
Now that the bike is finally home, I will have a close look at this. The surronding also seemed to have been a bit overheated, to the limit of melting.
Maybe an inadequate light bulb, or, a ground problem, underneat the dashboard ?
Anyone have encountered this problem before ?
ToddC
Seven Bays Wa
2006 ST1300A
Look up sun scorched wind screen/ dashboard. Somewhere I read something about sun being intensified from the rear and focusing a magnifying glass style beam at the dash. Like when parked at the wrong angle and it has time to cook. Just a vauge memory.....
ToddC
Ron
Orlando
ST1100s
2432
A lot of the 1100 have a deformed mark in that location but I've never seen one to that extent. Looks like it got pretty hot to bubble like that. I don't buy into any of the "sun" stories. I live in Florida and mine spend a lot of time in the sun headed in any and all directions. Some have it some don't.
Obo
East Coast Canada
'03 ST1300A
I'd agree it's from the windscreen focusing sunlight on the dash like a magnifying glass when everything aligns in the right (wrong) ways.
If it was heat from something underneath you'd not see the rough marks, only the deformity. The marks in the melted bits tell the tale of the heat being from above.
Maybe it's Honda's example of a freckle. :)
fnmag
R.I.P. - 2020
Desert Southwest
'06 ST1300/Burgmn400
Similar to @Ron. I live in a very hot place and have not had that problem.
Slydynbye
Will ride for Pie
Fremont, California
2000 ABSII
7331
It's not how hot the weather is it's how you angle the Bike/Windscreen. Think of a magnifying glass and the curved windscreen.
Ron
Orlando
ST1100s
2432
When I park my bike, probably the last thing on my mind is where is the sun? I ride to work and the bike sets out in the sun all day. It has been parked at every degree mark, all 360 of them, at one time or another. I never had the privilege of buying one new so maybe it is a stock shield that causes the problem. I use a Rifle shield that goes on as soon as I get the bike. None of the ones that had a deformity got worse and the ones that weren't deformed, got deformed. Anyone know what's behind the dash at that place?
Oman
ST1100AY
I'm pretty sure that if it was heat/sun related I would have seen it over here in the Middle east, neither of my bikes have any damage and they were police for several years.
It looks more like it was used as a cigarette holder !!
Edit: just realised the screens on my bikes are tinted so that would minimise the sun effect
rogo
Duluth GA
'05 ST1300
000406
Maybe one would need be at a higher latitude for a more consistent angle alignment with the sun.
illinois
2000 ST1100
Yep. Add me to the club. Funny Honda did not change the material of the dash to eliminate this. Oh well the rest of the bike is so perfect i can live with this.
paulcb
Celina, TX
'97/'01 ST1100 ABSII
8735
Yep, I've seen this on both of my ST11s and several others as well, in varying degrees. I will say though, none that I've seen are near as bad as the OPs.
The Cheese
Back when I smoked I would put a lit cigarette there regularly. Heard of others doing the same. It's a feature!
I'd say its 50/50. Sun or cigarette.
ReSTored
Mississauga, Ontario
2019 Tracer GT
4463
I have the same mark on my gauge as well + a much smaller ones on the edges of the speedo and tach. Bike parked in full sun sun pointing east for afternoon for the temp gauge meltdown. The others no clue. Something to do with the curve of the windshield, the angle of the sun etc........ I guess. Every once in a while everything lines up and "poof"
ChriSTian_64
2000 ST1100Y
9063
My engine got so hot, my temperature gage started to melt. hi hi.
I never thought the sun could be responsible. And didn't thought that was a common problem, eventough not everyone has experience this.
There is so many different windshield brand, lenght...
Unless it is the sun and the lens of the gage itself ? Is it flat or convex or concave ?
