I am on my 4th ST1100 now and this most recent one I picked up has a mild miss in the lower RPM range...up until around 3K. Then, it either goes away or is just less noticeable. It's a 1992 ST1100 with 53K on it. The previous owner says he replaced all the carb jets.
I have never removed or torn into the carbs on any of the ST's I've owned...count myself lucky, I guess. I used a STE synchrometer to synch the carbs yesterday and it didn't help. I've run a tank of Seafoam and next I have some Berrymans to run through it. I've only put one tank through it so far...I've only owned it for 2 weeks.
I am thinking I have a vacuum leak. I have a Honda manual....and, forgive my ignorance....which are the vacuum lines to check? Do I have to pull the carbs to check them? I know it could be the carb boots...I am not sure if the PO replaced them when he pulled the carbs or not...going to try spraying WD-40 at the boots and see if it changes the stumble. Also thought about the fuel cutoff valve....but haven't yet bypassed it...don't want to change too many things at once for fear of not being able to isolate what the problem is.
If I were skilled enough, I'd just pull the carbs and check the jets and do the idle drop test, etc....but after reading how to do those...I am feeling a little intimidated to tear into that myself...and I live a long way from any other ST-Owners or liSTers. So...is there anything I can do without removing the carbs?
I am ordering new spark plugs too...and going to check the plug wires. So trying to cover a lot of bases...but I still think it's probably the carbs.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
