Miss my Flash to Pass Switch
Seattle
All my other bikes have had a flash to pass switch. I do find myself missing it on the ST.
While on the subject of ST... you all have made me see ST all over the place by emphazing it sooooo much here... lol. I now see ST (Street) and I'm looking for an real ST.
Yorktown Heights, NY
1799
Here I am!:D
What is a Flash to Pass switch?
rjs987
Robert
West Des Moines, IA
2022 Kymco AK 550
001059
8058
I had one of those on my Burgman 650. Only worked on low beam since the flash was to high. I ride high beam (modulated) from sun up to sun down. On my ST I use the starter button. It does spin up the starter motor a little but it doesn't even catch up to the gears on the road so no bad issue there. Besides, seems the BDCs notice a light going on/off more than just hi/lo, and it's a change up from the modulation.
tlartist
Tom Laux
Fall River, WI
So any issues with using the starter switch? Do you just keep pressing over and over to get the desired effect? Really no issues?
Posted via Mobile Device
Mark
Gotta make tracks
Moderator
Apache Junction AZ
KTM 525exc
3768
Your starter switch cuts power to the lights and runs the starter; and although I haven't kept it up for long, pressing it multiple times doesn't seem to do anything other than flash the lights.
Uncle Phil
4 ST1100(s)
005185
698
The ST1100 U.K. version had one (which you could order from over there). Several folks use them as PTT buttons. I don't know if they have the same set up on ST1300s, but I don't think so cause I don't remember one on the ST1300s I rented over there. But then the old memory ain't what it used to be either ... ;-)
Avtrician
In Oz, its a high beam flash switch. Its a trigger like switch lever on the front of the left grip. On ex police bikes its quite likely that it doesnt work as it has been converted to a PTT switch.
juddspaintballs
Dual Sport Touring
Berkeley Springs, WV
KTM 1090 Adventure R
7186
I put a european FTP left switch housing on and converted the button to PTT for my Icom radio. If I remember correctly, the wiring and plugs are different for the US bikes and I quite literally just changed out the top half of the shell, leaving the original light switch and wiring in place. I know several people who have used small momentary switches and put them in the FTP location for a PTT as well, so I don't see why you couldn't use a momentary switch and wire up your own FTP switch either.
Perth, Western Australia
2010 CB1100
8289
ST 1100 Pan (in Oz) has a high beam flasher as described earlier, plus a high/low beam switch, but no "headlight off" switch. The lights are permanently on when the engine is running, as required by law. (I think since about 1985 or so. My old 1984 Beemer R65 has a headlight off switch.)
Interesting that US bikes don't have the same setup.
W0QNX
Blacksheep Tribal Member
Pensacola, FL. USA
06/ST1300 19/R1250RT
007437
I use the starter switch to drop the lights and signal others. It doesn't spin the starter because starter won't spin with the clutch out and bike in gear??.
Raymond
Viggo
Minnetonka, MN
2008 Goldwing
6833
I'm pretty sure the starter motor does not spin if in gear and clutch is out so the only effect is to kill the headlight (and tail lights too? I haven't verified this.) All other accessories stay hot.
I've used this more often to signal a trucker that he may change lanes in front of me. Keep in mind that flashing your headlight on/off may have a different meaning than flashing high/low beams. All such signals may be misinterpreted by cagers since there is no universal meaning to them so be careful.
rjs987
Robert
West Des Moines, IA
2022 Kymco AK 550
001059
8058
My Toyota Corolla has one and so does my Nissan Murano. No issues using the starter switch on the ST since I only flash it a few times very briefly. I have heard something spin up when I do hit it. If not the starter, then what? I think only a scooter has a cut-out for the starter motor since you must hold one of the brake levers to start those. But I think the starter on the ST will spin without holding the clutch. May be wrong about that... think I may test it tonight with the bike in neutral and not holding in any levers while pushing the starter.
I had the left control cluster apart the other day and notice there is a removable cover for a switch or something on the front side of the upper half of the cover. My guess is that is where a PTT or high beam flash switch would fit. Would have be a VERY low profile on the backside/inside part of the switch since there is only about a 3/8" space (or less) from the housing to the handlebar.
rjs987
Robert
West Des Moines, IA
2022 Kymco AK 550
001059
8058
... All such signals may be misinterpreted by cagers since there is no universal meaning to them so be careful.
All such signals WILL be misinterpreted by cagers... most cagers don't know what communication on the road is and show indication, more often than not, that they are puzzled by any signal other than turn or brake signals. And they only partly understand those! The best you can hope for is that any signaling you do will cause you to be noticed and don't expect more than that.
W0QNX
Pensacola, FL. USA
007437
QUOTE]
It will start in neutral without the clutch in but not in gear.
Raymond
RCS
Stamford, CT
I use my hazaard lights. People move to the right and begin to slow down really, really fast. Hmmm...don't know why?:D
