This winter I replaced my thermostat and O-ring, along with the big hoses from the radiator to the engine and stat housing (the easy to reach, big ones), and put new Breeze clamps (replacing the OEM clamps) on the hoses I could reach. Did not do anything more to drain the old antifreeze - such as pull plugs on the block. After I filled the system and overflow tank, I burped the engine by running it until I got one bar on the temp gage, revved it a few times, shut the engine down and checked hoses for leaks (none), checked the radiator (full to the cap) and topped off the expansion tank to the full mark. Then I put electrical tape on the expansion tank with an arrow pointing to the fluid level with "Full to here" and the date. Few days later I test rode the bike for about 40 miles - no leaks. Did the Mansfield RTE and put about 230 miles on the bike in one day, and discovered that a full lock turn disconnected my heated gear coax plug extension wire in front of the forks. At the beginning of the ride (in light to heavy rain) I smelled hot fluids - probably rainwater and juices that I spilled on the exhaust when I drained the a-f, oil, and maybe a drop of brake fluid during my winter service. These smells went away as the ride progressed and rain stopped. Temp indicator was pegged on 3 bars for the whole ride - I kept checking it to make sure the new stat and hoses had not failed and dumped all the coolant.
Today I pulled off the left middle cowl, made the heated gear coax wire longer, and noticed the fluid level in the expansion tank was down about 1 1/2 inches. Looked under the bike, and as far aft as I could see with a good flashlight on the right side. No evidence whatsoever of leaking anti freeze. Checked the left side (which was completely open) and also saw no leaks, dried a-f, or any sign that there might be something amiss. I looked everywhere I could see without pulling more tupperware than the left middle cowl, left inner cowl, left lower cowl, and lower inner cowl behind the front wheel. Nada. Engine runs like a sewing machine.
Is it common or likely that there were air bubbles in the block that were replaced by fluid from the overflow tank? I probably added less than a cup when I topped it off today. Bike is ready for a ride tomorrow.
