Hi guys. My bike was charging around 15v at 3000rpm and quite probably cooked the last battery. So I bought a new yuasa battery and one those mosfet regulator super kits from (Roadster Cycle) and after much trial and error I managed to squeeze it in the original RR's location. Very complete kit btw. The new one is quite a bit wider than the stock one so it's a tight fit. Not much to hook it up. Of course I cut the stator wires and soldered them to the supplied wires and hooked up the other two wires to the battery and I find out it isn't charging at all. The original connector with the other wires was put aside and taped up like the instructions said. Has anyone tried one of these for an ST1100 and if so what problems did you come across. Of course the solutions to those problems. I also tested it using the roadster cycle video and it checked out fine.I feel like going back to the stocker and putting the new one in my Vfr instead. Thanks in advance.
