So you mean we gotta use common sense and THINK about what we're doing?He is... and MCrider has an excellent response video.
For me, it is a matter of speed. The slower you are going, the better counterbalance works, the faster you are going, the more weight transfer helps.
It isn't one or the other, it is situationally important to know both!
so the lawyers can say "we didn't tell you to do that"Sheesh, how come every complex question has to be answered with "it depends".
I can relate to this greatly...as can my 6 month recovery from a sprained ankle and torn ligaments in Death Valley. The day was epic - a bunch of guys ripping along on our XT250 and DRZ's - Saline Valley, Lippencott Mine Road, The Racetrack, Teakettle Junction and a bunch of abandoned mines in between - great riding and not a care in the world. The long day started at Panamint Springs and getting up over 7000 feet at Hunter Mountain...things got cold, very cold! Not sure of the "Murican" temps, but I know for the rest of the world it was 23C in Panamint and felt damn close to zero at Hunter Mtn - there was certainly a good amount of snow that didn't look like it was going anywhere. From a vantage point near the top of the mountain I could see our temporary home and visualized the food, the beer, and most importantly the warmth that awaited us. This is when I came down with a bad case of "barnitis" as the affliction is known - most common to cows at feeding time as they race for the barn. I came into sweeping turn, downhill, on gravel, and came to realize I was going a bit hot - too hot to apply the brake which would have righted me and shot me into the cacti, so I did what my years of road riding said.....countersteer and lean into the turn.....and wham, down I went. In retrospect - the post mortum clearly indicates I was tired, it was the end of the day, and I was riding too fast for my condition and skill. The same rider earlier in the day (me) would have leaned out of the turn, applied the throttle and put down a leg for good measure....so yeah, complex problems require complex solutions - and my brain was simply not computing by that time of the day....Having to frequently switch between road riding technique and dirt riding technique is challenger, in my case the more dirt riding I do the more my road riding degrades, I'm sure its due to the opposing techniques required, don't think I'll be applying my dirt riding body positions to road riding any time soon though
He, Motojitsu, Motorman Palladino, and others probably, have made response videos:He is... and MCrider has an excellent response video.
I'm supposing my style is visual/instinctive. Absorb and assess road conditions ahead, aside and behind at a quick glance, because a split second later those may change. Same with a scan of your instruments. Similar with locating all the controls...signal switch, horn, dim switch, shift lever, brake pedal...if you have to look for them or feel around for them, you need more practice. If you have to think/calculate your next move, you're likely road food at some point.Some people are primarily visual. That's their learning style.
A very successful and wise man I know once told me, "I can't even talk without a whiteboard."
+1 Sometimes I see responses that are the equivalent of saying "you forgot about holding your pinkie finger out when holding the cup" or "NO, the milk goes in before the tea".What Ryan said doesn't seem controversial to me, but it looks like it is to others.
Sounds like being marriedI'm supposing my style is visual/instinctive. Absorb and assess road conditions ahead, aside and behind at a quick glance, because a split second later those may change. Same with a scan of your instruments. Similar with locating all the controls...signal switch, horn, dim switch, shift lever, brake pedal...if you have to look for them or feel around for them, you need more practice. If you have to think/calculate your next move, you're likely road food at some point.
