Moved on from the ST1300 to a 2018 Vstrom 1000 XA
ak85lp
(Paul)
Franktown Ontario Canada
2018 VStrom 1000XA
Well after 7 years of owning an ST1100 and 3 years with the ST1300, it was time to try a different ride. Last summer while riding out of our trailer park site, I wasn't sure if I was going to get out the gravel road after a big rain without a big tip over on my ST1300.
I sold the ST1300 last month and I'm the owner of a 2018 Vstrom 1000 XA with only 8500 kms on it and some factory warranty left :). It came with a center stand, hand guards, lightweight skid pan cover, aftermarket exhaust, aluminum side cases, and 2 seats. Many of these items were stock with that model.
So now onto a review of riding it for about a month and 500 kms or so. I will try not to compare bikes as they are 2 totally different rides. I just want to focus on likes/dislikes.
First, this bike is over 200 lbs lighter than the ST which makes it easier to move with your feet when parked. Also gone is the annoying heat from the ST. I know others have tried modifications to fix that but I never bothered. On a 25C day you would feel like you were in a sauna. The V has a bit of heat coming back to let you know the motor is working but that's about all. My V has been lowered by the previous rider but I am going to raise it back up very soon. I bought the Givi Airflow windshield which does make a big difference and an Air Flow seat cover that I tried out yesterday. I bought some mirror extenders from Rick at Adventure Tech as I was looking at my shoulders. I have yet not been able to find the top case I want, as the area between the side cases is narrow.
Since the suspension is still in the lower position I haven't bothered to adjust the sag in the front and back. The ride feels stiff to me which could be the lowering and or me being a heavy rider so I hope that can be sorted out soon. Other folks like the Wee but I did not want a 650 as my wife has one and I prefer more power. This one has plenty of power for passing and just general fun!!! I love the ease of how it turns without any effort at all and the clutch lever could be easily be used with 2 fingers. Brakes are excellent and the motor is very smooth at all times. Riding at 100 km/hr results in about 3600 RPM in 6th gear. I think the ST was around 3500 RPM.
I have only ridden some gravel roads for a short time and did not feel like I did on the ST where I wondering if I was going to get through to the end due to the weight. Gauges are very easy to see and provide all you need without having to flip through the modes on the handlebar. I averaged 55 miles per Imperial gallon (2 tanks) so far with mixed riding. Since the ST used premium fuel also that didn't bother me at all. Oil changes will be very easy too as everything is easy to get to underneath.
Likes - less weight, no more blasting heat from the engine, nimbler handling, better suspension (I hope soon), excellent ABS brakes, lots of power, nice upright riding position, smooth engine, just the right amount of extras like the12 volt outlet and 3 level traction control
Dislikes - very susceptible in a cross wind, stock seats are brutal as most OEM seats are, mirrors are too close together
Overall I am happy with it so far but it will take some getting used to after riding STs for over 10 years which I knew would be an adjustment period.
Hamilton Ontario
6811
Nice looking bike. I’ve been thinking of the vstrom 1000 too, because of the weight. Rode an older one before and really liked it, except for the chain. Hopefully will hang on to the ST13 until weight is just too much
houston, tx
Is there an echo in here??
ak85lp
ak85lp
(Paul)
2018 VStrom 1000XA
Update on this after 6500 kms last season. I have since raised the bike back to the original position and it's very nice. I'm 6 ft and I don't think I would want it any higher. The suspension I think is good now, a little harsh on some roads but overall good. The mirror extenders were definitely needed and I have a threaded mount for my GPS in there too. Added a small top box to the back large enough for my helmet and a few small items and next will be to replace the stock seat. I swapped the tires out to Shinko Trail Masters and they work very well and much more reasonably priced then other brands. My wife runs them on her Wee and loves the tires.
Also gas mileage is excellent at around 60 miles per Imperial gallon. Even on a cold/fast day it only drops to about 54 miles per imperial gallon. The bike calls for premium and I have used that as well. Chain adjustments take about 5-10 minute and oil changes are very easy as everything is easy to get at. The bike has lots of power for an old guy like me and has a 6th gear as well. :)
The Vstrom is a breeze to handle in the garage and you can even walk it around without sitting on it. It is very nimble on the twistiest roads and literally falls into corners with out any effort. I miss the comfort of the ST on longer trips but not the weight or the heat. Since 95% of my riding is under 400 kms in day, I think I made the right choice for overall riding.
ak85lp
ak85lp
(Paul)
2018 VStrom 1000XA
Yes , I had a look at both owner manuals (V and the Wee, and they both say "clean, lubricate and adjustment as needed every 1000 kms" I usually take a look about 1000 - 1500 kms myself.
