So i have a 1999 st1100. Has spark, fuel pump is sending fuel to the carbs, must be getting fuel through the carbs because the plugs get wet, regapped the plugs just to make sure it was not a gap issue. Done a timing belt on it and that belt was plenty tight and timing bang on. Had it running a few times after it was all mechanically back together, let it run up to temp before shutting off. Now today went to start it and drive it up the road and it kicked once and now just rolls over. So i checked all of the above and this is where i am at. So not in the mood to poke at this and take alot off of it. Too me just sounds like its flooded, i had left it sit for a few hours and tried again and no luck.
