new back fire/ popping on deceleration??
United States
91 1100 with 136,000. stock exhaust, K&N air filter
well maintained by yours truly. Recently on deceleration I get a popping . Used to be smooth no noise. Air leak?? Where to Look first?
jfheath
John Heath
Ilkley, W Yorkshire, UK
2013 ST1300 A9
000679
2570
I would suggest the vacuum tubes which are capped off to provide the vacuum take-off for carb adjustment. The ends should be just visible at the top side of each of the cylinders above the plastics cover lids. They are connected way down into the V - needs a light and mirror to see and long, long nosed pliers to push them back on.
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
Afterburn.
Exhaust manifold/muffler pipe leak/hole.
Air cut-off valves.*
Secondary Air Supply System fault.* (Easy to check!)
Hoses of emission control system fault.*
* p5-2 Honda Service Manual, Troubleshooting
Edit: if the engine runs smooth I’d think the intake side (intake manifold ports or carb boots) isn’t involved... Air is getting into the exhaust side. Some decel burbling is normal but the OP is reporting a change/something new.
jfheath
John Heath
2013 ST1300 A9
000679
2570
Edit: if the engine runs smooth I'd think the intake side (intake manifold ports or carb boots) isn't involved... Air is getting into the exhaust side. Some decel burbling is normal but the OP is reporting a change/something new.
I bow to John O's superior knowledge on this. My comment about the vacuum tubes was from personal experience when it turned out that one such tube had been disturbed at some point, and came off mid ride. Lots of popping and back firing - but reading my notes at the time, there was also a very obvious loss in power. (0-60mph in about 3 mins ! I exaggerate of course, but not by much).
kiltman
Stratford, Ontario Canada
2002,ST1100ABS
8826
I'll go out on a limb.... side stand switch starting to go, red wire coming loose at the main relay, that can cause backfire, or popping on deceleration.
