Dinkie Diesel
------------Jeff------------
Just replaced the front pads this morning with 55,000 miles on the OEM pads. When I had the bike inspected in March they said my front pads only had 400-500 miles left. I pulled the caliper, cleaned the pistons and lubed up necessary parts with Teflon dry lube. Polished the retaining pins (should have replaced them but didn't have sense enough to order ahead of time), pushed the pistons in to their retracted positions and installed the new pads. Only took about 22 minutes.
Now I have a question:
Why did my front brake lever change the point at which the brakes start grabbing? I'm having a hard time conceptualizing this phenomenon.
From my experience in the mechanical world, a hydraulic brake or clutch is a self-adjusting system. As the pads wear the pistons come out of their hole and leave you with a pad that is within a few thousands of touching. I was also taught that a certain amount of rotor run-out was good/needed to actually throw the pads out away from touching continuously.
Since putting the new pads on I now have a lot more front brake or put another way, I don't have to pull the lever near as far before the front brakes kick in. eg. My brain says if I used to have to pull the lever in 1-1/2" and that squirted 3cc's of brake fluid in the pistons why do I only need 3/4" of travel or 1-1/2cc's of fluid now? Shouldn't that remain a constant?
Sorry, sometimes I just geek out and need closure.
