NEW thermostat stuck open?
Glad you got it sorted out with the T-stat.
Sounds like it would be a good idea to lift the tank, check the air filter, and maybe consider cleaning the plastic 5 way tee out, replacing the lines, and doing a TB sync.
My bike shows 55-59 mpg at 80 mph on the freeway, and I always get an average of mid to high forty's.
How many miles on your bike?
JimGregory
CT USA
07 ST1300
I'm not absolutely convinced I didnt tweak the new Tstat but maybe it's fine.
I do have a new 5 way and some spare hose just waiting for that job. The air filter is brand new. The old one looked fine. The bike has 14,250 miles. I got it last spring with 7500.
I know that I have never seen over low 40's any time ever in the last 7000 miles. I though that was an urban myth.
The bike runs sweet though. Always has and never missed a beat.
Could my staintunes possibly mess with this?
Dave.David
Rider
SB California USA
05,ST1300-04VTX1800R
8938
I've only had my ST 1300 for two or three hundred miles and getting around 33 miles per gallon. What is the 5 way and hose ?
000540
Circled in green, thanks to supersabre for the image
000540
That didn't work as well as hoped. Do you know the name of it so I can look it up in the book?
17201-MCJ-003 but, you don't have to replace them, you can just remove and clean them out with a pipe cleaner or the like. They usually collect gunk over time.
000540
Thank you Mellow. Is this under air box, air box has to come out?
yes, but not all that difficult. Plus you get a great view of the throttle bodies and all the connectors to just give you peace of mind that it all looks good.
JimGregory
CT USA
07 ST1300
if you are placing a parts order like I do every so often with partzilla, it's good to get little inexpensive bit's like the 5 way connector. It doesn't wear out, but it can break from ham fisted home mechanics like myself.
THAT SAID, the most popular reason for bad fuel mileage is the thermostat has gone hinky. Your bike likely could use a coolant flush anyway, so read up on the 374.5 threads on coolant change and thermostat issues. It's not that hard at all and a good initiation to the world of tupperware. And the bleed hole goes UP.. at 12:00 please.
000540
With all due respect, I would NOT start banging around on the plastic snorkel housings with an impact driver, or you risk breaking stuff.
Before you try to remove ANY screws that look like phillips head screws, you need to purchase a set of JIS drivers (mcmaster carr).
All the screws on your bike are Japanese Industrial Standard (google it) not phillips head screws.
You can remove the airbox and snorkel screws easily with the proper JIS driver without risking damage to anything.
I would also suggest getting a small magnet to attach to the shaft so you don't drop any screws down into the black hole :rofl1:
JimGregory, I attempted to email you, but am having problems with my computor. If you pm me a contact number I will call you on the white courtesy phone and chat if you'd like.
Vernon BC Canada
09 ST1300
+1 could not agree more. The ears on the throttle bodies that those machine screws thread into are tiny, and a downward strike from the handheld impact would certainly bust things. Don't get me wrong - those impact screwdrivers are indispensable tools, but the weak aluminum casting won't take it. Get a set of JIS drivers. They fit a lot of stuff on import cars too.
000540
Okay don't work yourself up into a riot. At the time, didn't know about JIS screwdrivers and I didn't hit the impact driver with 100 lbs of force LOL! I simply tapped it to loosen the screws and it worked perfectly without damaging anything.
