Mine's a '94. I bought it with 17,000 miles and it has 36,000 miles on it now. I upgraded my alternator last year. It was still working fine, but it had started to leak. The old 29 ampers are oil bathed. Good idea, but over time, and think about it, my bike is 27 years old, the big o-ring that seals the alternator to the housing goes hard and they'll start to leak. The research I did indicated that then they start to leak, they soon go out. So I replaced mine.
I guess if it's still making juice and not leaking I'd probably run it unless you just want to do it. One thing the up grade does for you is to get rid of the external voltage regulator and the associated wiring and plugs that get hot and fry on these things. Being a new owner, whether you decide to upgrade it or not, you'll want to check out those plugs as they are all bad.
The write up on how my upgrade went is in the alternator portion of the forums. There is a terrific loaner kit that has everything you'll need, with instructions on how to do the upgrade.
I got my 40 amp alternator on line. I think I actually got it through Walmart! LOL. The hardest thing for me was finding the 40 amp base plate as the Honda plates are not available ANYWHERE ANYMORE except for salvage yards, but there is a fellow on the forums here who is now selling new plates that he has had made. I believe he sells them through ebay.
My write up is here:
I started this upgrade a little over three months ago when I realized the 28 amp alternator on my '94 was leaking. Honestly, the hardest part was finding an Adapter base plate. You cannot buy them new anymore. A hundred or so phone calls and e-mails later, I found the whole shebang, a used...
www.st-owners.com
