@Andrew Shadow quote
In post below
This answer fits with the short answer that I got from the suspension shop.
If it’s low, it has a leak, time for a rebuild.
I would think it could be like a car tire and need a maintenance top off now and then.
I measured the pressure with a no loss valve. That would be no loss when adding air. Taking a measurement costs about 1 or 2 psi.
It was at 140. 150 is spec.
And while the shock hand pump was there I topped it off.
So I went off in this direction because the new shock sagged less than the old shock that was supposed to have been set at the same preload. I figured gas pressure must be the difference.
Whatever the case thanks for the knowledge and thoughts.
As it stands the 06 has a soft total highway comfort ride that is fine.
The 06A with the fresh shock is going to the twisties this weekend.
More on that later.
